I have a different problem with my autobox (EFII XR6). When I floor the accelerator, i will occaisionaly get a grinding noise from what I think is the auto. Will also do it on hard takeoffs when changing from 2nd - 3rd. Any ideas on what this could be?
mmm...kilomawatts...aargh
I sometimes get the same problem with my EFII (XR6) Ghia. Only happens rarely but enough to make you stop and think! I have asked the service guys at Ford and they have no idea! Even after checking the whole engine out. (but it's comforting to know someone else gets the same thing, I thought I was going crazy :)
Hi Steve,
Yeah the Ford guys know absolutely JACK. They can barely handle a lube service. I once complained of a drive train rumble @ 120km/h - they told me it was tyre noise. Turned out to be a bent tailshaft! Good to know I anit the only one with this prob! Cya!
O
Hi paulmc and Steve
just going thru the old posts looking for a clue on funny boing, boing, boing noise coming from the rear shortly after I floor the accelerator on EL XR6 auto. Sounds like cyclic grinding noise. Not sure if coming from gearbox or diff. Lingers for a few minutes then disappears.
Your experiences seem the closest. Any further comments to date? can any one else shed light on it?
By the way this model also has no oil filler tube. Crawled underneath to check oil level and filler plug obstructed by exhaust pipe. I guess Ford means it when they say "never needs refilling" :-(
M
hi steve dave & onehunglow
this sounds very much like the noise that
was coming from my box,now my torque converter is spilling oil all over my drive way I thought it was the front seal it wasn't
now it seems i have to pull the converter & crack test it but I think the impeller has broken off inside thus making the noise
so take it easy & get it checked before your car is parked up for a spell with oil pissing out the box like mine
O
Hi Michael73
Thanks for advice.
I've also had similar experience to paulmc regarding unbalanced tailshaft and diff noise. Both were replaced under warranty at less than 10,000kms. Makes you wonder dosen't it?
