Black 200kw wheel barrow
have just baught an "aerpro" replacement mast for my AU as it didnt properly retract whenever the ignition was turned off
id just need to replace the mast itself and not the entire motor and everything right?
and if so, how do i go about disconnecting the existing mast from the plastic toothed belt and then attaching the "belt" to the new mast?? the replacement has f**k all instructions
or do i need to replace the entire thing?
BA'o'Matic 100% working.
DONT QUOTE ME HERE - Pull out the entire arial, then the bottom half unscrews, slot the new centre in, then do it up again, and re-install - this is from memory when helping out a garage of what was done on a volvo i think, so would asume the same.
Hope it help ???
Jason
Hope it help ???
Jason
theres still the matter of somehow disconnecting the old mast from the "belt" then reconnecting the new one to it
Well one way to find out, rip it out and give it a go, otherwise ring the local garage and ask them very nicely what they know.
Jason
