Hi Jim, go for the chromies but purchase wisely because there are 2 types of chroming on the market - dipped & sprayed. Dipping is the more traditional way giving a better finish (smoother & more resilient) where as spraying can give a slightly rippled look & if not done properly, can peel. Most 'cheap' wheel deals, like the ones in the 4 cylinder magazines, are sprayed, they're not bad but check them carefully for pitting & you can tell they're sprayed if only the face of the rim/dish has chrome on it. As far resilience goes, they're not as easy to patch from gutter marks etc as say a fully polished rim but they're easier to clean because brake dust hoses right off, the dirtiness your friends are talking about is more to do with brake pads & not the wheels. Another point is watch the offsets, Kelli mentioned the blue EL with 19s, its actually Vince's car & he had a bit of mucking around with rim fitment: pumped/lipped guards, used spacers on rear & longer wheel nuts - but the car sits extremely low, another alternative is fully polished like the Simmons on Tomi's green EL XR8 under the owners gallery.
