1 - 11 of 11 Posts
Hanging Around
Hi,
does anyone here work in spare parts for a ford dealer?
Im chasing some info, basically I want to know if the:
Distributor pickup,
Distributor shaft and spider,
TFI module,
and MAP sensor
Is the same part number between EBII, ED and EL falcon, or if it was changed.
If anyone can help it will be appreciated.
9psi EB
moved to the pub. Figured it would be better suited there since it is not really a technical question but a sourcing of information.
The cat in the hat
pick me pick me!!!! yeh..the distributor assy for MPI is the same for EA/B/D and EL...oh yeah and the map sensors are the same too, EA-EL
Often has bolts left over
would you be able to tell me whether E-Series window regulators are interchangable from back to front, left to right? my drivers window is ****ed, could i swap it with the rear one?
LOOKING FORWARD TO NYE!!!
/me can see partsguy being verrrrrryyyyyy busy in this thread!
The cat in the hat
partsguy only sells parts...no idea on the timing issue...
And no the window regs are different for all four corners...which is a bitch because RHF is currently not available from FMC (back ordered since early Dec.) and probably wont be back until mid March..my RHF is clunking badly too.
/me goes back to sleep now
bugger..
I presume they are all the same regulator from EA-EL? how about AU?
hehe get me an EF airbox with trade prices :p j/k
Those things are bloody expensive!
by the way, what do you have to do to be eligible for trade discount? Im an apprentice mechanic, do i have to produce something?
1 - 11 of 11 Posts
