1 - 10 of 10 Posts
well i sometimes i have the problem when the cruise has been on for ages that it wont turn off with the off button, i will press off, and put my foot on the brake. then when i press of again, it resets the cruise speed. it only does this now and then.
i pity tha fool
actually i wouldnt mind wiring up replacement circuitry with a custom setup of switches to replace the steering wheel mounted buttons. that way i can place the new assembly of switches somethere else on the dash/steering column and fit any aftermarket wheel on..
actually i already have the aftermarket wheel on and would like my cruise control back.
Hanging Around
oldxr said:
you mean if its not setting or if the light on the dash dosn't even come on?
Yeah, if the c/c module isnt turning on, ie you cant hear the relay clicking, and the light doesnt come on.
jmartion
If you are after a schematic on how all the buttons work, let me know, I'll draw one up for you.
SE QLD SVO OPERATIONS
hey all, im also after the pinouts for the speed control unit, the 16pin unit ..
many thanks if anyone has one!
BA'o'Matic 100% working.
Mine didnt work when I got my car, the light came on, but nothing happened, after checking everything out, I found that some twit and turned the brass adjuster so far in that the cable was so slack it couldn't do anything, so i tries to adjust it, but it had been like that so long is was siezed, after removing the cable, and half a can of WD40, swearing, hitting, and 2 odd hours later, it came loose, adjusted it out, and all fixed :0)
Jason
Thanx 9PSI EB.. that would be great ..
1 - 10 of 10 Posts
