1 - 15 of 15 Posts
CEO - The BSR Group
Pursuit Reincarnation Dog
EL2:
To use this throttle body you need to bore out / machine the inlet to the plenum to match. Take that into account!
If I remember correctly the Cobra Intake or GT40 manifolds are able to take a 70mm throttlebody without machining that is if he has one or getting one.
The cat in the hat
OUCH!!
throttle body part number is TAUTVE 9E926 A
RRP on this bastard is $847.00!!!
intersesting though the egr spacer is the same across the board.
maybe it will fit.
CEO - The BSR Group
WHOAH!! :eek: :eek:
Dat not cheap!! Hmm, you may be right.. if the spacer is the same, .... *ponders* Will see if Southside know anything..
Thanks mate! :thumbup:
CEO - The BSR Group
Ok an update. Just spoke with Alan at Southside, he reckons that yes, with the spacer it shouldn't be a problem to fit. Also, the price they quoted me was a little lower at $783, but still pretty pricey. The SVO 65mm unit is currently $565.80.
*opens wallet*
*flock of starving moths fly away in horror and anxiety*
*begins crying like a little girl*
Hmm, got some saving to do! :cussing: :fmad: :(
Be sure about that machining thing. Tickford machine the manifolds for the 220 engines, so it makes sense that it has to be done.
CEO - The BSR Group
True. Alan was also saying that on the T-Series, they run a manifold which doesn't have a spacer... haven't looked close enough to check this out..
When the time comes closer I'll be scrutineering, never fear!! :D
BBK -
70mm - 75 mm $529.95
70MM EGR Spacer $149.95
75mm EGR spacer $175.95
Holley -
70mm - 75 mm $559.95
From VPW
Much cheaper than $847 !
CEO - The BSR Group
Discussion Starter #10
Not wrong mate!! Ta for that info. Anyone had any experience with these units? Comments?
70mm is pretty damn big for a N/A 5.0L motor pushing only 300Hp, the Mustang Saleen S351 (Supercharged 5.8L) with 500Hp had only a 65mm....
There has been Magazine articles in the US proving that you make more Hp with a 65mm than a 70mm on a 'mild' tune N/A 5.0L.
Holley and BBK are good performance brands so you shouldn't have any problems with them.
GTHO4:
I hate the idea of animated signatures. But I broke my chair when I saw that one. Damn funny, in fact I'm ROTFLMHO*
* Copyright DOC Enterprises 2001
CEO - The BSR Group
Discussion Starter #15
Ok another update - it looks like that new Tickford unit has an EGR spacer built in to it, so it should be a straight bolt-on for my Explorer upper manifold, according to Herrod.
Just taking a look at the engine bay of the T-Series, doesn't look to be a regular EGR spacer so this sounds right! :)
1 - 15 of 15 Posts
