The hinge is available separately and they can be replaced in 5 minutes (the voice of experience).
Part number AU F060A80 A8 - should cost around $13.00
Russ
known as tibbo
YEp it is a easy job.. Remove all the phillip head screws attaching the cover to the black plastic inards, take the padded cover right off, slide the pins into your new hinge then reattach the cover and screw it back up...
Tip: make sure you have the two pins or get one when you purchase the new hinge
