1 - 20 of 54 Posts
Woodsa
Howdy boys
I just finished putting in my 2001 AU XR6 VCT motor into my 89' SVO. but I haven't started to wire it up to the EA dash, now I am running the AU computer and engine looms and im trying to match it up to an ED ghia dashboard loom.
I need a WIRING DIAGRAM for an AU??? anyone got one or anything that can help? I will probably need and EA one, although I seem to get the gist of it just with time.
I have found a wiring diagram on the net but they want $150 for it! that is more than i'm willing to spend. I'm not that desperate, YET. if anyone works at ford and could photocopy it I would be willing to hand over a little dough.
any help would be appretiatted.
PS the motor looks great and slid straight in, almost anyway. if anyone wants photos or anything I could post them up??
Birth, Drift, Death...
please!!! tell us what you had to do with the heater pipes, fuel lines, radiator hoses, AC pipes and all that stuff! OED 666 and I are going to be putting AU engines in our cars soonish, (like, whole engine, serpentine drive belt, AC compressors you name it) and it would be great to know in advance what we are going to have troubles with!
and congrats big time man - an XR6 VCT motor wouldnt have been cheap!!! last time i asked a wreckers they wanted $3300 for just the motor!!!
Good to hear mate!
Get the Gregory's, I managed mine with that - unfortunately I then lost the damn diagram I drew up :/
Basically it's just a case of slicing into the EA computer loom at the gearbox plug and matching wires, i.e. O2, power, earth, etc. Took me about an evening to do the actual wiring, had to run an extra wire for the AU O2 sensor as it's a 4-wire setup as opposed to the EA 3-wire (same plug though). Smartlock will run the AU comp with no dramas, that's the other thing you need to do - find out the wires that meet the dash i.e. speedo, windscreen washer, a/c, etc.
The thermofans will require a little fiddling as well, I never did mine though so NFI what...
Oh BTW the trip computer won't read correctly now. Sorry. :)
Rollin - Heater pipes were cool, just used the EL one, tho the EA MPFI ones would have been fine. As for the AC, I was cool cos mine's got more than 6 ribs, so I just put some longer bolts in and a few spacers to push it away from the block. Before that, the belt was rubbing on the tensioner. It also made the required belt length greater, unfortunately.
If you wanna change to the AU compressor you're looking at big trouble, I didn't even go there as the two systems are so vastly different! :fraz: My suggestion is to get a good s/h Sanden compressor with lots of ribs - probably cheaper than an AU one anyways...
Everything else was cool, p/s fits fine and I just squashed the EB radiator hose down onto the AU pump. Did a shitload of high revs and never blew it off - blew off the heater hose a few times tho!
Ran real cool that way even without the fans, provided she didn't sit in traffic too long.
Regards,
Alex
Woodsa
Hey Rollin...
I haven't tested this all yet so don't hold it to my neck that it works but this is whats been done so far..
I picked up a 2001 XR6 VCT engine with loom and computer for get this.... $1500 thats 1367 or the like not icluding GST. I've seen the car is out of a silver XR6 with 46000 km on it and no marks or anything in the engine bay or the engine. he gave me a different cars computer and loom. to begin with he told me $2500 not neg! I came back a month later said one grand VISA, 500 cash he said no worries. I you live in VIC and want any ford parts send me a Msg and I'll give details.
About fitting, firstly remove the old motor and change over the mounts, Grind a fair bit off the front of the sump( just wait until you go to slide it in, then you will see where it doesn't fit, BUT REMEMBER that when you first put it in the motor tilts backward so don't take too much off; it will fit better when it sits level. then fuel lines are easy just get a few inches of pipe and cut the two lines at a similar spot put the pipe in both and put hose clamps on. about the heater hose. mine was a MPfi EA and the pipes didn't fit. the AU pipe bends down at the end, I cut that bend off the AU pipe and the EA pipe went straight on.
about the A/C compressor, I stuck with the AU so I didn't need to regas the system, or upgrade etc. you can use the AU aircon mount but moved to different holes with the EA compressor, or so it looks thus far. mine is all fitted but i'm unsure if it will all work.
There are a few other things like there being no place for the coil pack because it ussually fits on the AU engine mounts, so I made one up out of a steel Shelf bracket.
my EA bell housing for a manual didn't fit on the AU sump(holes didn't line up) and I would feel bad telling you to modify or something may break so get the AU bell housing if possible.
The AU starter was smaller than my EA one so i got an EF one, but i was told EB's have smaller starters too.
you will need to run an AU accelerator cable if you dont have the variable length runners(ie EA to ED/EF not sure bout that.) I don't know if EL or EF cables fit, also you will need the vacuum control solenoid, should get it for free, its tiny and controls the Variable lenght manifold.
wow, that was a speill. got any more q's just yell out.
You lucky bastard - and so cheap! I wish I could do something like this, only thing is I'd have to pay someone to do the whole lot :( Talk about a sleeper.
Woodsa
Rymers;
The Vacuum control solenoid is found above the left( looking from inside the car) wheel arch at the back tucked away, follow the vacuum lines at the back of the motor across, two vacuum lines plug in to it,and one two wire plug. tiny black thing.
Woodsa
Discussion Starter #9
sorry boys dad has taken his Digi Camera will post them tommorow.
cheers
Bell housing won't break if you stick with the EA one :s6:
Looking in YOUR bathroom.
the Vacuum solonid is behind the washe bottle. The EA body work has the holes for it allready there.
No longer around
galapogos01 said:
thats where the cruise pump goes in an EA Fairmont though?
cruise pump??? what does the cruise pump????
also, simon
its out of an XR6:p
mongrelEB i talked to an ac specialist the other day, he said that i should fit the motor and compressor and then take the car to him, and he can just bend up some pipes and braze on the proper fitting for the compressor pipes.
the EB and AU setups are very very different, but they both do the same thing...so by just using the EB pipes and putting a new fitting on the end for the compressor it should all be sweet.
Woodsa
Discussion Starter #18
sorry bout the wait guys shouldn't be two more days, can't get dad to bring the camera back from work
Woodsa
Discussion Starter #19
Oh if anyone is from Melbourne suburbs and wants a look, just PM me, Im over in NE suburbs. cheers
Sounds like a good idea Rollin!
It's just that the other (EB many-rib) compressor can usually be swapped for, i.e. no cost.
Alex
1 - 20 of 54 Posts
