1 - 14 of 14 Posts
Ford Member
Hey,
The service interval on my AUII XR8 ute is 15000 km's or every 12 months.
I know this is the factory standard but should the old t least be changed befoer this interval - 15000km's is a long time for oil IMHO.
Am I just being old fashioned?
Old Car:BA XR6 New: 97 EL
I refuse to change the oil every 15,000kms in my AU2...!!
I read this article on oils that says 10,000kms intervals should be treated as absoulte MAX.
With every 5000-7000kms being the best,
Here is a bit of the article:
"You thought you where doing the right thing. You remembered to change the oil and filter every 10,000 kms. Yet after your car ad covered 100,00 kms it started to blow smoke. Worse some expensive-sounding rattles became apparent.
In todays new car market, buyers expect to budget for the exact costs of ownership over a specified period. The car companies have responded with amoung other things, set maintenance schedules. And the pressures on them to make them even longer."
etc etc. anwyays its a long article but the gist of it says not to let oil changes go past 7,000kms, if you want your engine to last!
Ford Member
Yes, this is what I am thinking - I have done close to 10K in my XR8 ute and I am beginning to get a little nervous. I might have to schedule a change of oil for it one afternoon this week.
Any oil suggestions?
Copyright �2003
I do a oil change every 5000k's. Better safe than sorry.
Ford Member
Thanks guys..I am now officially freaked out.
I might have to go down get some oil and change - have done just under 10K with the original oil.
Do I need to change the filter or can it wait until the 15K service.
My name is Forrest....
Always pays to change the filter as well, for the sake of such a cheap component, it gives peace of mind.
Aussie Falcon Enthusiast
Changing the filter with the oil is mandatory not optional!
After enough gunk is filtered out of the oil and trapped in the filter's fibers the filter will activate a bypass and the oil will no longer be filtered. Considering that oil is the lifeblood of an engine then the cost of 5 or so litres of good oil and a decent filter every 5,000 km isn't all that much. Anyone who has felt that sharp, stabbing pain in the hip pocket after hearing nasty noises from the engine will attest to that. (right Kelli? Oh wait, it was a dodgy timing cover on yours hehe)
I myself have been running Caltex Havoline and a Ford racing filters of late and am doing fine. Of course it helps that the previous owner had the car serviced every 5,000 km from new for the 5 years before I bought it.
Ford Member
Discussion Starter #9
Just changed the oil on Both cars and it came out looking like dirty water.
The Forte on the service interval - very,very bad looking
The XR8 5K odd before the service - pretty bad, very thin and crappy looking.
Looks like its changes every 5-7 from now on.
anakha,
Where do you get these filters??? and how much??
I've been running my car at 10,000 intervals, mainly due to the fact that at 5000k I'd be changing the oil every 5 weeks!
With the drive I do 1 hour to work each way at 110Kmh, I was under the impression that the oil would have the chance to burn off alot of the impurities that blacken it at help keep it clean. Am I wrong in this thinking?
Officially Bored with 347
No you are right to say that longer drives do infact burn off some impurities to a point, Its the really short trips that do harm to engine oil ie round the corner to the shops thing.
I change oil & filter every 5000k's & have always been fussy about this, including fuel filter.
At the mo Im using Shell Helix ultimate with no real dramas to think of , it used to be 15/15 but now is 10w/40, the oil press. gauge does sit lower than b4 especially at idle but any noises that were there b4 have gone ie ticking from valvetrain.
i also use an additive called "EF" Eliminates friction which im hooked on
Has anyone here tried a "Hard Driver" oil filter?? fully synthetic internals?????? Seem to be the go but are worth $20 ea!!!!!!!
My suggestion is three months or 5,000 km max (whichever is first) oil and filter. Cheap insurance.
While the long miles over short periods are better for the oil and the engine the hotter engine temperatures that can be associated with long high speed driving trips can also be detrimental (and especially if the previous owner was a stop - start driver all that built up sludge can be released in a long high speed run).
Never seen or heard of this before. Where did you get it and how much???
Currently running Caltex Softec 5w40 (or something like that) and have noticed very similar results with oil presure and valve train noise
Jesmol
Yes like svo302 said its constant short trips that really necessitate the need for frequent changes. If most of your driving comes from long highway trips then you can probably get away with 10k changes. Still its pretty cheap preventative maintenance to change it more often.
I used to have my filter changed by my mechanic (still do at the 10k intervals but in between I'll buy my own. Specialist Ford places sometimes have them or alternatively if you buy the Champion heavy duty filter (you'll know it when you hold one hehe) that is the very same filter - just rebadged by Ford.
svo302
Hard Driver are rebadged FRAM filters IIRC from that well known oil filter info page that is online somewhere. I believe at least one of those models has teflon in the filter which is supposed to be a real no no according to Dupont.
1 - 14 of 14 Posts
