Should be 12 (91 LE) or 13 (95 LE)wires runniing between them altogether. However, the harness with two wires (one white, one violet) tells the ECU what gear the trans is in.
One will be aircon staus and the other engine temp status? The auto software has programs for when the A/C is on and when engine temp is high. The other thing it could be is what Aussieblue mentioned as the engine ECU has a stratagie for when the car is in reverse. Torque reduction mode to protect the reverse gear. I know in that mode it sends a freequency 25hz or 50hz depending if its in reverse or not
