1 - 20 of 21 Posts
Has anyone had or heard of any problems or faults with the BA Turbo,as I am thinking of purchasing one.
APS Phase 3 Ute
All new models have some problems, on some cars, mine hasn't missed a beat!
I just bought one dude, and Ford and its employees have been told to focus on quality for 2004.
Mine will be a Feb 2004 build, and I'm hoping it will be fault free. I know that a number of rolling changes have been implemented over the last 12 months that have fixed most of the known problems. With the Turbo, there were faults on the earlier models with some software in the engine managmeent system. Wheels experienced this when they assessed it in the COTY for 2002, but this known problem was fixed very quickly with new software burnt into the computers FLASH memory. I assume all new cars would have this software. The brake shudder problem also seems to be disappearing on cars built over the last 3-6 months, so it seems that Ford is getting on top of that one. There are probably more, but these two seem to be the main ones...
The car I test drove before buying seemed very solid, and was quite good on quality. Mind u my test drive only lasted 15-20 minutes, but I went over her with a find comb tooth to see if I could find anything dodgy, and everything looked solid. I am particularly impressed at how "solid" the car "feels", which is probably a combination of more weight and the terrific grip the car has. It gives you alot of confidence in driving it, which makes you want to "plant it" more often.
Good car dude, and with 240kW, it'll be a while until any other manufacturers catch-up. Go for it !
I can understand all cars have faults,but my primary concern is the actual turbo itself and driveline,wether or not it can handle all that power.I just hope they don't go the way of most turbo cars,forever in the workshop.Thanks very much for the feedback.
The turbo itself is just fine; it's a fairly large unit rated to around 650HP, it is only having to cope with 6lb boost in stock form, so it's relatively unstressed, and should last many years without problems whatsoever.
As for the drivetrain, at standard power levels it should be just OK. If not, replace under warranty. The manual gearbox, with a max torque rating of 447NM, is at the torque limit of the motor.
I've no idea why you think most turbo cars are "forever in the worshop". I have 4 turbo cars, and strongly dispute that comment.
Modify the car, and it's another matter. If an auto, go to 260-280rwkw, and your best to upgrade/strengthen your auto; if manual, go tor 280rwkw and you'll need a new clutch, as it will slip, over 300rwkw and you'll possibly destroy your gearbox (how do I know: mine is stuffed).
Brian
Hey Primo,
I have had mine for 3 months, done over 5500kms and it has not missed a beat. Mine is a Oct 03 build so a lot of the little fixes have already been applied. Yours will be even better.
You have 3 years warranty for a reason so if little things come up Ford should fix it. I have owned several cars from new and whenever I have had a problem the dealer has always fixed them - inc Holden.
Good luck with your car when you get - you are going to love it to death like all of us. :driver:
That comment 'forever in the workshop' might have been a little harsh,but I have friends who have had turbo cars,and it just seems that they are always fixing something ( VL,WRX,200SX).You may be right,push something hard enough and it will break.
OFR #7
xr6t8u said:
...Modify the car, and it's another matter. If an auto, go to 260-280rwkw, and your best to upgrade/strengthen your auto; if manual, go tor 280rwkw and you'll need a new clutch, as it will slip, over 300rwkw and you'll possibly destroy your gearbox (how do I know: mine is stuffed).
Brian
Sorry to highjack the thread, however I am very keen on buying an XR6T!
Brian,
What have you done to achieve over 300rwkw and what are you planning to do about the gearbox?
Big ****,
I don't want to hijack this thread, so I'll start a new thread.
Brian
I should probably read the rest of the replies, but..........
It appears that the drive train of choice is the SSS Auto, unless you absolutely must change gears yourself. It's stronger, has less hassle with drivetrain clunks and thumps and will cope better with any mods that you do. If you cast around you will find that the consnsus is that the Auto is good for upto about 300kw, whereas the Manual is marginal at standard power.
Primo:
the Garrett GT40 turbocharger can handle up to around 700HP. it is the 2nd or 3rd best turbo in the Garrett range. Garrett are a very respecatable brand of turbocharger.
Check out some of the other forums on the XR6T and you'll find that the manual box has proven to be stronger than the auto. Some of the aftermarket tuners have development mules which have been happily running well beyond 300KW without driveline failures.
Having said that, you can break anything if you try hard enough....
▲▼I ♥ XR6T's ▲▼
Im buying one for my 21st Birthday in August. On;y $10,000 more to save :D:D
RACE
XRDREAMING said:
Hi All,
My first post here. I have had mine for over 6000km Aug 03 build and even with a few mods it is perfect so far.
Good to hear XRDREAMING, and welcome to the forums.
I have an April '03 XR6T with 37,000kms showing so far. It's never let me down but I'm sick of taking the thing back to have the brake shudder 'fixed'. My next visit to the shop will be my third and I've no faith in the rotor skimming solution. Other than that, I've suffered a weeping radiator, occassional stalling when hot and a few bits of moulded plastic have dislodged themselves in the cabin (this seems to be common with Fords) and yesterday, the bonnet release broke, so the car goes into the shop again on monday.......
gone
Damm
So many new users all in one thread
Welcome to all the newbies!
Go introduce yourself in the New Members forums
RST2000 said:
PRIMO
pm me and l'll pass on a desginated xr6turbo site thats worth looking at..
cheers
Whats wrong with this site that not worth looking at?
Rip Up The Track Join OFR
RST2000 said:
PRIMO
cheers
don’t you think its worth looking at the above response's...
1 - 20 of 21 Posts
