1 - 20 of 27 Posts
Pursuit Reincarnation Dog
I'm interested in talking about owner experience of anyone on here who's done a blown 290. Particularly interested in the 5M setup. Driveability? Traffic behaviour? Tyre wear he he he :wnc: ? Is it Stage 2 or is it the intercooled setup?
Thanks, AP.
When 2 T3s are not enough
Yep a mate has a cappa on his GTP 5speed 303 rwkw with standed exhaust, and no intercooler, he is putting a cappa exhaust system on it this week so Ill ask him how it goes then, as for the driving, its as sweet as a nut just more grunt everywhere from idle to rev cutout, again sweeeet as, I think its running 6 pound boost,So what are you planing AP ?
I'm always planning - it's just funding that I'm not so good at.......
Two SC 61's = trouble
T76 ???? Don't wast that exhaust energy...
I've never liked turbos. Sure they do a job but there's simply not the driver-car-engine responsiveness I crave.
YES its a 5 Speed!!
unreal tho when they come on boost... its addictive the rush!!! supercharger would be good to tho ;) :hy:
Yes you are right Pete BUT have been in a V8 turbo?? Or any big capacity motor turbo'd?? Done right it's not like that...
Discussion Starter #9
EB:
Yes, I've been where you're saying but there's always a lag. There's no getting away from that. I don't even like the lag you get in an auto Commo V6 let alone a turbo. Crisp immediate throttle response is a true sign of a driver's engine!
Pete::
Check out "Kenny Bell" in the states they make a blower kit that sits under their manifold..Only problem is I think they like to FIT there own kits....
John may help out there ????
Kenny Bell make possitive displacement blowers....
C:\Documents and Settings\Owner\Local Settings\Temporary Internet Files\Content.IE5\IJGJN8XK\Dublin bus ad 1.jpg
My mates just done his pursute. Vortec charger, 3.5 " exh, deflippo extractors. Getting 437rwhp @ 4lb boost. Next mod will be intercooler. Very impressive vehicle to drive.
Vortec is Centrifical and about the same as turbo down low..Infact even worse as boost/ flow builds with rpm.Usually max revs is there max power.Unlike twin screw blowers...
greetings Squiz
dont suppose that you could post some pic's of that & let us know who fitted it ect
regards
rod
If you twin turbo'd it (which should be a near necessity on any turbo street engine over 4l) you would have really good response, maybe even better than a s/c setup. Plus you can get alot more power out of them for your money.
I can understand how a Centrifugal blower lacks low down go but can you please explain why a twin screw is instant.
Thanks.
The Kennebell kits look like a great bit of gear and exactly what your after AP low down grunt and instant response.
Thanks.
Geese I know I'll get flamed here but I'll try....
A centrifical works on throwing air out[anything for that matter], at low speed it won't hardly work..
Take a pool pump which is centrifical turn it slow and it won't work.But at 1600+ rpm it works gangbusters..The opposite with a gear pump as in hydaulics works bloody good at low speed but falls away as revs increase..But works better at pressure as well..
Expain that right ???
A T76 single would work well almost instant spool..
Anyone who has driven in my car has never complained of lag, there honestly isn't any..Maybe different with new engine."Lower" static compression...
1 - 20 of 27 Posts
