MAF, we are talking BA here, it doesn't have that problemTopGhia said:Stick with the paper filter.
If you use an oiled filter, at least get an oil analysis done and see how much extra dirt is getting into the engine. (Will show up in oil analysis as raised silicon levels).
Also check your MAF wires regularly for build up of crud, this will affect performance and negate any dubious advantage of running an oiled filter.
cheers
Surely these filters would be safe to use if maintained properly. eg don't use compressed air to clean them etc.TopGhia said:Stick with the paper filter.
cheers
Yeah I used air (once)...rod c said:Surely these filters would be safe to use if maintained properly. eg don't use compressed air to clean them etc.
Have you had a bad experience with one?
I was talking to Barry Batten tonite and he said Ford endorse the use of K&N filters, they can't be that bad.dicast said:this may sound dumb but if something goes wrong with my engine will ford still cover me or is it alright to use aftermarket airfilters/cold air induction???
TopGhia said:BAXR8 doesn't have a MAF?. Please enlighten me, what does it use to meter air flow into the engine.
cheers
Nothing about BMC filters there......... As a mate of mine said the engines are going to wear out eventually, you might as well enjoy the maximum performance you can while you have it.TopGhia said:Anyone?
Trouble with an aftermarket filter, who wants to admit they are wrong? Read this thread and make up your own mind.
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=15;t=000175
:wnc:
The BA's use a Manifold Absolute Pressure sensor (MAP). It uses the sensor in the manifold to record the air pressure which allows it to measure how much are is being used and then calculates how much fuel is needed to add to it.TopGhia said:BAXR8 doesn't have a MAF?. Please enlighten me, what does it use to meter air flow into the engine.
cheers
