you cant use the tapered pods as they hit on the air box. you need a straight cylinder type, and fit via a 3" tube into the alloy trumpet in the inlet. but if its too hard to find one just go a flat panel k+n. if you have over 60k kilometers then you should look at replacing the platnum plugs and or the leads(for the miss). dont get genuine ford leads at $940 a set. go for top gun at $100.. cheersXD408 said:Thanks for the info, im waiting to get the exhaust done and servicing the motor as it has a little miss down low, what air pod did you use and how did you set it up?
ye gr8 advice top gun leads!!!!! u gotta b joking, i prolly wouldnt go genuine at $940 either however i would go a decent quality lead like a bosch or ngk. does any1 make and electric water pump 4 those motors? i know on a holden u can get sum gr8 gains in kw.xrglen said:you cant use the tapered pods as they hit on the air box. you need a straight cylinder type, and fit via a 3" tube into the alloy trumpet in the inlet. but if its too hard to find one just go a flat panel k+n. if you have over 60k kilometers then you should look at replacing the platnum plugs and or the leads(for the miss). dont get genuine ford leads at $940 a set. go for top gun at $100.. cheers
just built one, with the same cam and same 185cc trickflow heads for my 347, in a AU 2 with 5 speed. should get aprox 320rwhp but with 80% of my torque from 2000rpm. long live the 347..DJS351XD said:Trickflows work better than a AFR's on the 5.0's. More torque/power in the midrange.
We generally use a Comp Cams 35-351-8 hyd roller in the EFI Windsors we build, with Trickflow heads, late model intake setup and an upgraded fuel pump you'll make approx 286rwhp from a 5.0 and 310-320 from a 347 stroker.
