mygt said:why? do you want to put one in a vs!
cheers..
How much does the alloy block weigh?CSV_LS1 said::shh:
Thanks Boss 330 :afro:
Around 43kg.aston said:How much does the alloy block weigh?
I'll take a 40kg weight loss any day, 40kg less in the front of these cars will make a huge difference, especially in handlingaston said:So the only advantage an all alloy BOSS would have over the current BOSS would be 43Kg....Does an alloy block have any other advantages other than weight?
Boss 330, What is this on http://www.seanhylandmotorsport.com/. Is this not right. Aluminium 5.4 Block 95 poundsBoss 330 said:A aluminum 4.6 block is 89 pounds. Iron 4.6 is 154. There is no production 5.4 aluminum block available at this time. Iron 5.4 ...184#
