DBA slotted or slotted and cross-drilled rotors (the cross drilling is really only for looks) will help big time, along with a set of Bendix Advance or Bendix Ultimate pads.Gunns said:I wish I had that sort of money to spend. I was more looking at what can be done to get more bite for under $1000.
Correction here, I've looked at this option & it's not that simple (thanks to Raptor for the info) as the AU2 changed the mounting of the ball joints from the suspension arm to the spindle (or vise versa) so it's not a simple changeover. What would be possible is adaptor brackets to mount the AU2 calipers, similar to what is done by Hoppers Stoppers on their upgrade kits.HOTDBZ said:Try searching around some of the wreckers coz you can pull out the brake system (together with spindles) from an AU 2/3 Falcon.
