2008 Mercury Mariner, apx 134,000 miles. Generally runs smooth. Several months ago, the brakes started grabbing, sometimes strongly, sometimes not at all. Further, sometimes I hear a rubbing sound when moving and sometimes the wheels shimmy at over 40mph or so. But this happens only occasionally, and I realized recently that it happens only when it's very hot out and I've been running the A/C for at least 15 minutes or so. When I turn it off, after 15-20 minutes, everything goes back to normal. Weird! Before I realized the AC was involved, I'd brought it in twice. They replaced the right front caliper, gave a wheel alignment, and checked the bearings, etc and could not find any problems (except that the caliper needed replacement, but that did not solve the problem).
It's a big mystery. When at idle the AC seems to work normally, although I did notice that it recycles pretty quickly.
Load test the alternator and battery as if any faults , the draw from the aircon can play fun and games with the electrics and sometimes give weird faults Simple test before you get too deep into it .
Thats strange that the AC could affect the steering somehow. The only link I can think of is if your car has EPAS then it's possible thats being affected by the AC or physically with the drive belts.
I believe the 2008 with the 3.0L - my car - has EPAS. But the problem seems to be more with grabbing brakes, sometimes load and severe, and shimmying than a steering issue. Maybe the shimmying is related to the steering but the big mystery is that in cooler weather - no AC on - car rides smooth and straight.
If it's the brakes , check for disc / rotor run out . Check the front brake hoses are o.k and not collapsed inside or damaged . If it's steering , the EPS is affected by low battery or alternator charging fault .
Thanks. More the brakes. I'm not a mechanic, but I discussed this several times with my mechanic and had brought it in twice (there had been a stability control sensor failure that caused all kinds of problems a few months prior so I suspected that). But he checked the brake system, sensors, bearings. He did replace a caliper and performed a wheel alignment but said he found no other issues but I don't know how deep he went. That's why it's a little frustrating in that there is definitely a big issue but it's intermittent and cannot be easily detected if it's not happening at the moment. But thanks all for your tips.
Related Threads
1.4M posts
115.4K members
Since 1999
