1 - 12 of 12 Posts
Crazed Cone Chaser
I have to get new globes for my high beam and I want to up the brightness of them as well as the low beams.
Has anyone had any experience with higher brightness globes in an XF.
I read part of a thread that was going on a while ago about changing the globes in a EF/L and was wondering if anyone knows if the same problems could arise with my XF.
Cheers.
Brighter lights
Hello!
I've just put in Sirius Halogen globes - I reckon they are about 70% brighter. I'm quite pleased with them, but at $50-$60 a pair, quite expensive. Beware though - one of mine was falty, and the manufacturer will not exchange because there is no warranty period at all.
Cheers!
Australian Ford Member
AusXH said:
I'm thinking that you'd probably have to 'upgrade' your reflectors as they seem to fry (over time) with the stardard globes, let alone brighter, higher wattage ones.
Most XF's I've seen (including a few hundred I checked at Pick a Part looking for better reflectors for mine) have the reflector surface dulling or yellowed or peeling, so it might be worth checking them. DON'T try to clean them with anything except maybe a very light wipe with a soft cloth. A decent rub or cleaning fluid will only make matters worse, as I found out the usual way. My XF had far better lights when I got it at a couple of years old than in does now, and the difference is all in the reflectors.
Shh i'm huntin more power
Paul,
I used to run 90/110 globes in my XD and it fried the high beam switch on the stalk. If you run a higher wattage globe make sure you install a headlight relay (you can buy these almost anywhere) that will eliminate frying any switches. You will still have problems with your reflectors though. In my opinion you'll be better off making sure your reflectors are good and running a +30 or +50 globe.
Jase
90/100
I've been running 90/100's in my XD for a few years now no extra relay, and I've only ever had problems when I added 2 100w driving lights with no extra relay, melted the circut breaker. No worries now I've removed the driving lights. Must be lucky I supose.
I own an XF and i have the 100w H3 globes in. They are much better than the standard globes and I have not many problems at all. Before that I had 130w but they just kept on blowing after 3-4 weeks. The 100w seemed to fix it but you can certainly tell the difference. I have had no problems at all with the reflectors going that yellowy colour that you see alot of XF's have.
One problem I have however is that if you leave High Beam on for too long, say 25-30mins the headlights black out completely. Extremely frightning at 140kmh in a black as black street.
Maybe someone knows how to fix it??? I'm suspecting the circuit breaker??
Crazed Cone Chaser
Discussion Starter · #11 ·
My guess is that the relay is over heating.
probably just need to get a higher current rated relay.
The standard High beams are 55W aren't they?
what are the low beam globes?
Fit a proper headlight relay and it will solve your problem. The wiring already there is only designed for standard wattages...
1 - 12 of 12 Posts
