I have a 2019 ford Edge 2.0 ecoboost. After I turn off the engine, the PCM relay in the fuse box starts to buzzing. Also with this, the relay works on the all-wheel drive gearbox. This happens every ~19 seconds, and it can be for several hours. I checked all possible problems:
Battery new
Mass perfectly contacts
The relay itself is fine.
If I do not use the car for several days, then it completely drains the battery.
What else could be the problem?
Rectangle Font Parallel Number Circle
