Ok heres the story.
Iv'e worked on motorbikes (hobby) for years .. so i know mechanics .. what I dont know is cars. With a bike engine, if a bit breaks, get a new one. With a car, if a bit breaks, theres options man! Options!
I know what a cam is, I know what a lifter is, I know what a pushrod is etc ..
What I dont know is .. Whats the difference between cam 'types' so to speak. I dont understand roller rockers, or 'anti-pump' lifters are, and I dont know why you need different lifters for roller cams Vs normal.
I ask this for 2 reasons.
If I may use your expertise, I wish to educate myself.
and 2, I own an XD 351c that underwent some luvin by a mechanic friend in Melbourne. He did all the hard work, I just bolted it in. The guy who did my heads put to much pre-tension (?? correct term?) on my valve springs and caused them to spring-bind (once again ?? correct term?) causing me to bend 2 pushrods in my first revolution (lucky she didnt fire really) anywho, so I replaced them and thought "What tha" got my mechanic friend over who diagnosed the fault straight away. He removed some spacers/washers from undernearth my valve springs. We got the beast running on a set of extractors and did a small run in around the country town it was at. changed the oil and I had a butload of filings. Thinking this was perhaps normal for my first oil change, i reloaded with oil and drove 170k's to home.
She sat in the shed for about 8 months while Life ran its usual course (long work hours) and I got her out this weekend. decided to check the vitals and found shavings all up my dip stick. Now I was worried. And after reading the forums .. I know exactly whats wrong. I've wiped the lobes of my cam.
After a small chat with another mechanic friend of mine, he totaly agrees ... :cursethis
Im gunna rip the manifold off and take a proper look, but I know what I'm going to find.
My current config:
Standard crank and rods, hypertechtic (no idea on spelling) pistons. All balanced and crack tested.
block is virgin, Torque bored and decked.
4V heads and chambers w/2V ports, so im assuming 4V valves as well. No remarkable work, just cleaned up. origional pushrods, and rockers.
Edelbrock Torquer with a 750dp Vac Secondrys.
I dont know what the lift/duration of the cam is, she had a mean idle (noticebly NOT normal) the cam cant have been to large, as im assuming the lifters woulda just packed it in, or i woulda shot a pushrod thru my rocker cover =p
So this is where I stand, in need of a new cam, lifters and pushrods. And quite frankly I dont know where to start. What cam would you guys recommend? Whats the difference in lifers? I dont spin past 6k. I also dont want to change my lifters if I can, I dont have all that much money to play with. And whats the chances of getting the cam out wihtout having to removed the engine .. I cant do that with what I have available.
thanks :hy:
My current config:
thanks :hy:
