Dont get me wrong but how are you supposed to get more power if you cant increase the RPM limiter? Everyone knows that in the normally aspirated world to get HP you must increase RPM. Now on a dyno a 5.4 290 boss is still producing power at its 6000 RPM limiter, the power curve has not even started to platue yet thus telling you that the cams fitted to a 290 boss have a lot more power left in them after the 6000 limiter.
on the engine dyno the 290 power plant was still producing power up to 6500 RPM at a constant rate and could do this all day the problem is that once the limit was taken to 6,700 all hell broke loose. a set a sticks may increase a little power between lets say 4500-6000 but is it worth the loss from the original 3000-6000 power band and will your shift points drop back into the meat of the power band having a 6000 rpm limiter?
my opinion is put the money towards a motec and piggy back it into the system to give you a 6250-6500 limiter. this is what im doing next on my GT-P and i will have a longer power band and more torque. A set of sticks are from what ive been told $4000- so another $1000 for a motec is within range.
Elmer Fudd
Elmer Fudd
