Australian Ford Member
If I advance timing, say a couple of degrees before the ignition mark used for base timing on my 3.9mpi, will the ECU treat that as a base and keep timing the same amount advanced throughout the range? If so, what's the best amount to advance it for maximum acceleration?
T5 Expert Operator
EA S,
In the EA's my guess is the timing will stay constant through the rev range. Ie if you have 2 degree's advance before TDC, it will stay that way right up to 4900rpm.
About what is the best advantage for acceleration, the rule of guide about timing advancing as i understand it is if you advance your timing and run a higher octane fuel you'll get abit more power and response. So if you plan to run the 98Ron fuels you'll be able to advance the timing more than running on a lower ron fuel.
After starting this topic and getting the reply, I stumbled on a statement in the factory manual which confims the reply. If base timing is out by x degrees, the ECU will be out by x degrees throughout the range, so timing can be advanced.
Australian Falcon Member
Yep, the timing will end up advanced by that much right thru the range - the ECU controls timing on a purely arbitrary basis which assumes the base settng is 10 degrees BTDC.
I've buggered about heaps with timing on my machine (used to carry a ratchet with long extension and 1/2 inch socket in the side pocket). It ends up being a trade off in that any advance improves response (and power?) thru the bottom and midrange up to a point (ie. the point where there's too much advance - at which point you get very obvious pinging even when accelerating quite gently off the line). The trade off is that any advance beyond maybe 2 degrees will impact negatively on top end.
Because I do a fair bit of open highway driving I now just leave mine at the std 10 degrees, but if you're in the city and want to improve responsiveness and make the old beast a bit more lively in the 60 and 80 zones, then it's well worth cranking it around a bit.
For town driving, you'll also find that advancing the std cam one tooth will make the car feel much livelier and improve fuel economy HEAPS - but forget about acceleration above about 130kph. Sort of makes it feel like a really hotted up V6 Commodore in other words.
