Whether 1-6, 8, 10 or 12 cylinders, 1-2 rotors, naturally aspirated, turbocharged or supercharged, the HALTECH E6K can control it.
I took that right off my little E6K "brochure" I got off the web. It does run off a MAP sensor metering system, but the MAP sensor itself is sold separately. I don't know why, though-just another way to make money. As for the injectors. If you are going to use this ECU, you will HAVE to wire the injectors to it. It would make no sense to get this and still make the stock ECU run the injectors. This means they will have to run under whatever system the E6K uses. it wouldn't matter if the E6K wanted to fire all 6 injectors at once, if you wire the injectors to it, they will do whatever it tells them to. What this would involve would be to disconnect the injectors completely from the stock ECU, you then hook them up to the E6K according to what 2 or 3 cylinders it wants to inject at the same time. Even if you unhooked them from all ECUs and hooked them up to a battery, they will fire, not under any control, but they will start spraying gas.
