1 - 14 of 14 Posts
· Registered
I have a 2018 Focus. Since yesterday, the boot release button is no longer unlocking the boot. Double-pressing the button on the key fob still works as normal to unlock it.
It was working yesterday morning. Wondering if I've accidentally changed a setting somewhere? Although I can't see anything in the manual about disabling the boot release button.
Thanks
· Registered
Thanks
BOOT???? is that a special model from texas??? never heard of a boot on a car much less a button for it
· Super Moderator
Listen at boot whilst someone operates and see if you can hear the boot lock actuator trying to open . You may need to pull boot trim , check for power and check lock assembly for possible water ingress or sticking which can often be cleared with WD40 or similar .
· Registered
Discussion Starter · #14 ·
Thanks for this. I've actually booked it in with Ford, but its a few weeks before they can fit it in, so I'll try and look at these suggestions beforehand and hopefully cancel the booking.
1 - 14 of 14 Posts
