1 - 11 of 11 Posts
EB wagon
Hey lads... Ive been looking into putting a supacharger on my EB. Ive been to the capa web page and they have a powerdyne s/c avaliable for the eb.
I cant seem to find what this includes?? What needs to be moded/added (apart from the s/c unit) to the car?? Is there computer mods and stuff also?
Thanks
Brent
Usually come with a chip or similar. (IMHO)if you want best result can the chip (-$250odd) ans spend a grand or so on a unichip. I put the vortec kit on my EL 6 and it was great. I then went the same Vortec on my auv8 and was great except computer management (BANG!!!). Pulled it apart and went back to stockish setup and sold s/c. Powerdyne if the $ aint there but Turbo!!! is prolly my next choice for my au as well as a well setup comp sys. Yes on the v8. I only intend on about 8psi with cooler. The vortec is better charger but harder to fit (oil lines) and extra $$$.
Oh but if you want the best setup on the falcon 6 GET A TURBO.
Just my 2c, hope it helps.
Oh, and the only other mods for a mild boost application would be to consider a headgasket upgrade. Port those heads while they're off good bang for bucks on 6cyl with boost.
Lamahs approve of manuals
Sorry about the horrendous formatting, but this was out of a doc I received from CAPA on what is in their kits for an AU 8
I'd just email them and ask for a list of whats included . . .
1. Supercharger assembly 1
2. Supercharger mount bracket 1
3. Powerdyne only -1 1/4 x 3/8 cap bolts and spring & flat washers 7
4. Powerdyne only -Top Brace ( Top of Bracket to Air - con pump) 1
5. Powerdyne only -Bottom Brace (bottom of Bracket to Air - con pump) 1
6. Powerdyne only -M10 x 65mm x 1.5mm bolt, nut and spring washer
(Top bolt to Brace) 1
7. Powerdyne only -M12 x 1.25mm x 20mm bolt and flat washer
(Bottom bolt) 1
8. Shim Kit 1
9. Powerdyne only -M8 x 130mm x 1.25mm bolt, spring, flat washers
(Brace to air-con) 2
10. Modified Radiator hose extension CH945 1
11. Radiator Hose Joiner Sleeve 1
12. Radiator Protector sleeve & 2 plastic ties 1
13. Hose clamps 33/57 3
14. 5/8 NF x 3 1/2" Crank bolt 1
15. Powerdyne only -M6 x 20mm studs (spacer locating studs) 3
16. Powerdyne only -3/8 NC x 1" Bolt, spring washer 4
17. Powerdyne only -Crank Spacer 1
18. Powerdyne only -Steel Crank Pulley 1
19. 500mm 2 Core wire 1
20. 400mm 4 Core wire 1
21. 1m Conduit 1
22. Wire Shrink wrap 200mm 1
23. 45° 3" Rubber bend shortened 2
24. Clamps 68/86 6
25. 160mm Aluminium Tube with blow - off grommet in middle 1
26. 110mm Aluminium Tube 1
27. 60mm x 75mm Rubber Tube 1
28. Air Filter Adaptor 1
29. Air filter adaptor to body mount bracket 1
30. M6 x 20mm bolt, spring, flat, nut (Air Filter Adaptor - A/F meter) 1
31. Angle bolts, spring, flat, nut ( Air Filter Adaptor - Air Filter 2
32. M6 x 25mm bolt, spring, flat, nut (A/F Adaptor - Bracket) 1
33. M6 x 16mm bolt, spring, flat (Air Filter Assembly - body) 1
34. K&N Air Filter Assembly 1
35. Thin 3" Silicon Hose 20mm wide (Air Flow meter seal) 1
36. Powerdyne only -7/16 NC x 180mm bolt, spring, flat
(Bracket - cylinder head) 1
37. Powerdyne only -Bracket to cylinder head Spacer 74 x 30mm - stepped 1
38. Powerdyne only - Supercharger Belt - 6PK 1400 (3.15) 1
- 6 PK1385 (2.9) 1 - 6 PK1375 (2.7) 1
39. Blow off valve 1
40. 90° 3" Rubber bend with Aluminium Sleeve (intake angle) 1
41. Intake Duct 400mm - calor 1
42. 330mm Blow-off Hose 1
43. PCV Breather Hose 300mm x 10mm 1
44. Throttle body cap & clamp - small 1
45. 10mm PCV fitting in intake 90° bend 1
46. Blow off hose 90° fitting 1" (facing towards blower) 1
47. 600mm 4mm Vac Hose 1
48. Brass tee pieces 2
49. Plastic ties (various sizes) 15
50. Clamps 89/108 2
51. Small package Stickaflex (Intake tube - Rubber bend on blower inlet) 1
52. Fuel management unit (FMU) ratio 8:1 1
53. M5 x 15mm allen head bolt, flat washer (FMU - Throttle body bracket) 2
54. FMU angle fittings 2
55. FMU mount bracket 1
56. 195mm High pressure fuel hose (Return on engine to FMU) 1
57. 300mm High pressure fuel hose (FMU to Return Line) 1
58. Fuel hose, hose clamps 4
59. Fuel hose protecting conduit 500mm 1
60. Computer chip 1
61. Powerdyne only -Idler pulley post 2" aluminium 1
62. Powerdyne only -Pulley spacer 3mm & washers 1
63. Powerdyne only -Pulley to post bolt 7/16" NF x 1 ½" 1
64. Powerdyne only -Idler pulley dust cover 1
65. Powerdyne only -Larger idler pulley 1
66. Powerdyne only -Pulley assembly bolt ½ " x 1 ¼" NF 1
67. Air Cleaner Protector shield 1
68. Synthetic Oil Only Sticker 1
69. Premium Unleaded Only Sticker 1
70. Precaution Air Inlet Low Sticker 1
VORTECH SUPERCHARGER EXTRAS
1. Blower oil drain fitting 1
2. Sump oil drain fitting 1
3. Oil drain hose 450mm x 12.5mm 1
4. Oil drain clamps 2
5. Oil pump Y piece 1
6. Oil delivery hose and fitting 1
7. Idler pulley - flat 2
8. Idler bearing spacer & dished washers 2
9. 3/8" x 2.5" Bolt, spring & flat washers - Idler pulley retaining bolts 2
10. M12 x 35 x 1.5mm Idler mount plate retaining bolts 3
11. M8 x 30mm special cut Allen head bolt 1
12. 7/16" NC x 5.5" special cut bolt 2
13. 7/16" NC x 5.5" bolt, spring and flat washer 1
14. Assorted plastic ties 10
15. Supercharger Belt 8pk 1615 3.15" 1
8pk 1590 2.9" 1
16. Crankshaft pulley 8rib 1
17. Blower pulley size 3.15 / 2.9" 8rib 1
18. Vortech blower - curved 1
19. Vortech Bracket assembly 1
20. Top Idler Plate 1
21. Bottom Idler Plate 1
22. 1 1/4 x 3/8" NC cap bolts spring & flat washers 5
23. T-Rex fuel pump system & relay switch kit 1
24. T-Rex Pump mount assembly 1
25. T-Rex rubber mounts 4
26. Insulated female Terminals 10
27. Insulated Round Hole Terminals 2
28. Fusible Link wire 1
29. 5000mm x 5mm Red Wire 1
30. 500mm x 5mm Black Wire 1
31. 2000mm x 2 Core Wire 1
32. Relay & Mount Screw 1
33. 4000mm x Conduit 7mm ID 1
34. 500mm x 5/16 Fuel hose and conduit 1
35. Fuel Hose Clamps 4
BA'o'Matic 100% working.
So you get the kit and all the extras, thats over 100 pieces, but wait theres more, we also thrown in .............. call now
Two SC 61's = trouble
Piss the FMU off and get proper sized injectors and maf..Using an 8:1 fmu/fuel reg is doing things on the cheap!!!!Not good for fuel economy/ EPA either they dump too much fuel as boost comes on, its not lineal enough!!!Imo..
For Spark control and you DON'T want to change eec, then I suggest either an MSD system or the Crane where spark can be retarded on % of boost...
Btw I think they left out a self tapper....Lol..
Blown ED XR6
I've heard of parts missing from their kits too...only heard...
Best off going to a performance place and buying a s/c and getting it all custom done. But then that costs more.
Twice the price and no r&r time! Hmmmmm. best to go with kit and modify part you not happy with. A lot of performance mechs do this! esp with fuel & ecu set up.
Also a few shops i've spoken too and the kit i installed on my EL doesn't fit up perfect so expect to shim and adjust a few times. Don't get dismayed if you throw a belt.
Blown ED XR6
Each to their own. I've gone the custom route, for reference.
I'll tip my glass to that Xeron.
I think one of the *big* benefits of the Capa kits is I think they are already eng cert'd - and I believe if the kit has approval, you no longer need to bollocks around with eng cert's yourself - the one they've had done transfers across . . .
1 - 11 of 11 Posts
