1 - 9 of 9 Posts
i have just boughta xb gs sedan with a 351 standard compression,2v heads,4v valves,tq20 cam,roller rockers,elbrock torker single plain,mallery twinpoint dizzy,650 double pumper 47772,4 into 1 extractors with 2&1/2 exaust with x pipe and will be having it dyno tuned soon, thought it might be fun to see how close a "gestamation" realy is if you want to try gess the rwhp :shh: . it has 3.9 9inch diff gears and a top loader. cheers
crochunter said:
I think you might be pushing it a bit with that hp heh XD CLEVO.
In Cairns it would be 220rwhp. hehe
G'Day 61oat,
Are these the TQ20 specs: 214/224 @ 0.050 .512/.536 lift?
I've got one of those little puppies. Good low down little torquey cam. The only difference to my setup is I run an MSD ignition (not that it'd add much), I have stock 2V heads, valves & rockers and a weiand xcelerator. I need a little heavier springs but can't be stuffed waisting the money on this combo....so I lose a fraction up top.
So.....after rambling on.......I make 250-255rwhp.
I reckon you should have 260-270rwhp. It'll go great with those 3.9's. My 4.11's are too low for that cam....still fun though.
Sounds like you already know the HP numbers? C'mon, let us in on them :hy:
Mine made 267RWHP with 750VAC, dual plane Perfomer, Genie tri Y headers, 3.0:1 diff and auto. Cam is a Crow Cams 211367 IN.33/73
EX.78/35 286
293 226
232.530"
.548" 2700-5800 RPM
"Popular hot street cam which delivers strong strip performance"
Heads are relieved closed chamber with standard sized valves.
You should make 270 easily.
1 - 9 of 9 Posts
