Did bought aan Imported USA edge from 2008 that had similar issues, partial likely caused by wrong re-warring.. "still some to fix here but majority done."
1. Check engine Oil
2. Check front row Injector coils and Spark plugs.
3. Check Air filter
Those 3 should give you indication of the car need general service.
Not Shure what happened with my edge but coils needed to be replaced around 88k done this with new plugs. As wel I took the throttle body off and cleaned it.
"if you not want to clean it, you can keep it on the intake manifold." Advice clean it and use new seals for intake and throttle body. DO NOT CHEAP OUT THIS PART YOU WILL REGRED IT!!!
This together with exchange of the Air filter for K&N performance for Original Housing, Oil service solved my Engine Issues.
"still slight trouble with gearbox and traction control. ;(. Assume 3 bad sensors. "Steering wheel angle sensor and speed sensor l and r front.
Prior work on the engine disconnect Battery and short the + and - connect by cable. "This will hard reset ECU" after that disconnect ECU.
Now you ready to disassembly
- Airbox and Housing
- Batter as it gives more clearance
- Disconnect all connectors and hoses, there ok reachable.
- Disassembly Intake manifold
- Cover open engine Part with clean towel "if some falls in there you fucked"
- remove Ignition coils
- remove plugs
- cover holes with towel
- drain oil
- remove filter
With exception of the adding oil you can now follow up in reverse
. Oil I add as last
Why at the point manifold and plugs are out, no more vacuum on any place within the engine Block.???
Not sure of it makes difference.
Make sure on first Start all electrics is off even radio as vehicle need to relearn Idle procedure, I did this for 5 min per gear position +10 with full ac in P.
Also some other system might need relearning please refer for those section to the manual as those procedures are described there.
