I picked up a 1997 Ford Explorer Sport 5 speed Manual Transmission at an auction. The check engine light won't come on to pass the smog test. I have checked continuity between the Instrument Cluster and the PCU. Replaced bulbs in the cluster and and replace fuses. I even changed out the cluster with 2 others that I picked up at a pick a part place. Any ideas as to what else is going on?
Verify you're getting 12VDC from your run solenoid and that your grounds are good.
