I have a 2005 Ford Five Hundred and recently had a misfire, so I changed the plugs and coil boots. I also cleaned the throttle body since I had to take off the intake manifold anyway. Misfire is gone and runs smooth but now wont shift into higher gears and RPM's way too high for lower speeds. "Check transmission" indicator is now on and the wrench light is on. Transmission fluid is fine at both cold and hot temps. I don't believe in coincidences such as my transmission is NOW ALL THE SUDDEN going out 5 minutes after the other repair. After reading the manual, the wrench light pertains to both the throttle AND the transmission. Am I correct to assume if the throttle body is still malfunctioning the CVT transmission will also malfunction since it senses what to do based on the performance of the throttle?
One other thing, like a bonehead, I broke the clip for the 6-pin connector to the throttle body while removing it. It still has a snug connection but not sure if it moves when the car is on causing a problem. Could this be the culprit or does anyone know what the problem here is? Cleaning the throttle body might not have been good enough and I'll replace it if I have to, but the transmission check indicator nor the wrench light never came on before when the car was misfiring and I could also go at higher speeds...just rough. And the transmission also shifted just fine before.
Could it be the broken clip to the throttle body or do I need a new throttle body? If so, will this solve the transmission issue? Is it a matter of resetting the PCM? Any help appreciated!!!
