1 - 20 of 30 Posts
methanol injected clevo
Hi there,
I'm building a bit of a warm 351:
SRP Sportsman forged alloy pistons (displacement @ 357ci)
Eagle ESP 3D forged H-beam 6.00" Chevy rods
4MA crank (might go for the Eagle if the crank isn't capable)
Grout filled XE Nascar 4-bolt block with main girdle
4V heads
Crower solid roller cam
TFC manifold
BG 775 carb
Now... i have a "few" questions...
A)
A mate of mine is running 3V heads on his 408 roller windsor and has the TFC manifold... untuned the motor pulled 455RWHP on a Dyno Dynamics dyno at a lazy 7000rpm... no spacer.
Another person i've met with a 4V head setup and TFC has said that a 1" spacer is reccommended with using the 4V heads. Has anyone else heard this? The carb will stick far enough out my bonnet as it is without a 1" spacer on it! (For curiosity's sake this is a 4V 378 stroker with 385 RWHP)
B)
Crankshafts.... I want to rev this thing to approx 8000rpm (yes this is the camshafts operating rev range)... what are peoples opinions on the Standard/4MA/4MAB/Eagle cranks. I've heard standard cranks are 75% nodular, the 4MA is 95% nodular etc etc.
Will my requirements exceed that of a factory crank? $900 for a Eagle may be more of an investment... snapped crank would spell the end of me and my passion for cars... :p
C
Toploader and 9"
The deal with my engine builder is i have to run a toploader :)
I have a standard toploader and 28 spline 9". I'm guessing i'll have to go full spool with 31 spline Moser axels... Will a toploader survive? Are a bull-nose toploader of any advantage? Any tricks i can do to strengthen the box?
Sorry for all the questions... look forward to your responses... I am looking for 350-400rwhp @ 10.6 comp on 98.
shane
at this power level i can't see your 4ma crank being a problem.remember back in the 70,s pro stockers were turning these cranks way past 8000 and this was with turned down big ends.tfc can be contacted on 03 93620266 .704 bucks retail.shane ,are you going to use the tongues in your 4vs?.how big a roller are you going to use?
What clutch set are you going to run?
Make sure you use a Billet steel flywheel and good hi-tensile bolts connecting it to the crank.
RAM make a good 11 inch clutch.
The 28 spline 9" should be OK. It's really only an issue if you are going to be using slicks - ie: the driveline is taking ALL the brunt. With just street tyres, they should break loose and smoke up before the 9" does......hopefully!
The bullnose toploader input shaft is 1 3/8" vs the standard 1 1/16". They are stronger but the standard ones are still bloody strong ;) !! I'd be quite happy sticking with it......money you can spend on the engine!
Oh, and make sure your toploader shifter is running nicely. They can be a bit clunky requiring a bit of manhandling.......if neglected.
Take it all apart and put a shifter rebuild kit on it.....especially the reverse lockout spring (can't remember the name of it) and the spring that centres the shifter.
Yes i'll definetly be using toungues in the heads. I looked at the unported intake runner of the 4V and couldn't believe how stupidly big those ports are!
At the moment my choice is a Crower 15484. "Ultra-Action/Performance level 5. Advertised duration - 311 intake, 318 exhaust - .759" .736" lift." Rev range 5500-8000/Redline 8250 plus.
"Mid-range and top end drag profile"
I plan on using the 3.5's, LSD and 28 spline axels to run the motor in. Once she's all run-in, registered etc. i'll be going for the 31-spline full spool with 4.5's :)
i've got a custom 2.5 tonne organic clutch in my 302W, could this be used?
if not i have a Hayes 11" clutch that was in it before i pulled out the driveline.
shane
shane
My Cortina used an 11 inch McLeod disc with a F100/F150 diaphram pressure plate. Nice and light under foot, and hooks up really well. 5 years of 6,000rpm launches and it was still as good as new. Be sure to use a steel flywheel and ARP clutch and flywheel bolts.
I also had concerns with my top loader. The input shaft is the weak spot. Fortunately it helt up ok but destroyed several 9 inch diffs in the process.
yeah i've been told the 11" Hayes clutches arent too bad at all for the strip....
i'm not overly worried about the toploader, i've seen several of them for $300-400, so i might have a couple as spare in case i kill one.
I guess my main concern is the diff... i wont be bolting on the slicks and going to the strip until the 31 spline full spool is in. The only reason it'll last on the street is because there wont be much traction!
might be needing a 6000 limiter for the street i think hehe
shane
Discussion Starter #10
well this will be fun..... =P
i know a auto will be quicker, but a manual will just be more challenging and enjoyable (for me personally) to drive...
shane
Discussion Starter #12
aiming realistically for a 11.5 with slicks.... we'll go from there (methanol tunes etc.)
shane
The Deputy Dogg.
Shane i am in the process of rebuilding my 351, it`s quite similar to yours, aiming @ between 350 and 400 rwhp plus 150 shot of gas, please keep us posted on your progress and end result, as i am interested to see how you go.
I am using 4mab crank, trw flat top pistons shotpeened rods, ported 4v, toploader, i cant give cam specs right now, as Hallam Performance will be selecting that for me in conjunction with Ray @ Crow cams, they tell me it will not idle under 1400 rpm, but the top end should be quite..........special :)
btw Brenx tells me that 28 spline axils are rated up to 1000hp, so i am not changing mine.
Nick.
GULP Thats huge!! I'm a manual man myself and have been looking at different cams, like the crane F246 3800-7800. with my 3.55 diff ratio.
With that cam rev range starting at 5500 how will the engine run below that on the street? will it be bogged down and labour along?
The Deputy Dogg.
clevo said:
GULP Thats huge!! I'm a manual man myself and have been looking at different cams, like the crane F246 3800-7800. with my 3.55 diff ratio. ]QUOTE[/
I currently run an F246, im going try an F260, or similar with 3.5 diff.
Sounds like that cam is track only, would certainly NOT be a warm 351 lol.
I imagine you will use oil restrictors or a high volume sump ?
I bought a pro eliminator today, it holds 8 litres and has scrapers to stop crank splash : http://www.highenergy.com.au/page3.html
Discussion Starter #17
don't get me wrong, i wont be building this motor by shortcutting.This car is not PURELY being built for the street. In fact it will probably be a pig on the street.
a) restrictor kit will go in for sure (without it at that kind of RPM things wont last long
b) already have a baffled sump made up
c) HUGE PWR oil cooler will be used
d) big gearing (4.5's) will keep the motor from bogging down hehe
e) 4 bolt mains, main girdle, stud girdle etc etc...
Typo? I think you'll find the F246 signs off at nearer 6800 - if not slightly lower.
Yes, it will be an undriveable pig on the street, but boy, will it fly!!!
28's are rated less than half that. Something like 400-450hp from memory.
Discussion Starter #20
1 - 20 of 30 Posts
