ive got an EF fairmont. the problem i am having is that the clock and climate control display is not illuminated. It is working, because if you look real closely you can see the numbers and pictures etc. I was just wondering if this was just a blown globe or something behind the display or is it something more serious?
any advice will be much appreciated, thanks!!
your on the right track. they run an illumination globe. quite common for them to blow. you'll need to remove it as the globes fit in from the rear ,
