· Registered
I have an '84 Bronco II with a toyo kyogo 4-speed that won't shift into gear. The clutch hydraulic line was empty. I check it once a month so it happened suddenly. I tried to refill the line so I could look for a leak but I can't pump the fluid past the master cylinder. I have little experience with automechanics so my questions are:
How do I bleed the clutch line? I didn't find a bleed screw on the slave cylinder.
The hydraulic line is made of a pre-formed, red colored hard plastic. If the line is cracked, do I just replace it with a rubber line?
