·I just install the Mustang K member into my 91 LSC. The LSC "tech page" would lead you to beleive that this is a direct swap? (and it could be? Maybe it's my installation?)
It did fit once some of the bolt holes were hogged out. But it was NOT a direct bolt in piece. All the bolt holes lined up
perfectly except for 3 of them. The front upper bolt hole, on the drivers side, required a little elongation. However, the 2 inner bolt holes, that attach the K member to the subframe required MAJOR modifications to allow the bolts to be installed. There is almost a 1/2" differance in spacing between these holes when compairing the LSC & Mustang K members. So, you better have a die grinder or some other tool to open these holes up. Also, you'll need to drill some 1/4" holes in the Stang member if you plan to reattach your brake lines like they were mounted on the LSC member.
I aquired the K-member from a 1989 V8 Mustang for $75.00
Also, there are 6 different suspension codes for the SN95, V8 convertable front springs. If you call Ford to purchase a set, you best have the spring codes on hand. I called a dozen Ford parts depts. and without the spring codes, it seems that your **** out of luck trying to purchase a pair. In the end, I could NOT purchase a set of new springs from Ford, due to NOT having the spring codes and no-one at Ford could provide any assistance in solving the suspension code trivia.
(If I'm not mistaken, LSC-R warned me about this a while back?)
Anyway, just wanted to share my experience with everyone. Someone once said they welded up their own upper spring seats and kept the stock LSC K-member in place.. This might be quicker solution than the Mustang K-member trick, and unless it's just my dumb luck, the TECH PAGE documentation needs updating to include alot of missing information.. We hoisted the Stang K-member into place, started to install the bolts and then said WTF!
The front coil swap is still underway, and I'm interested to see what other issues arrise??
