I have an '02 Taurus with 85k miles on her that I just bought. Today when I was checking something under the hood I noticed this metal line cold and dripping with water...
51479
I had the air on but turned to the position of arrows pointing out of the dash and floor vents only. The defrost or a/c function was not selected. It seems to be doing it consistently. I haven't traced all the parts of this car's a/c system yet but I don't know of anything else under a hood that turns cold and sweats. Why would my compressor be working when it's not selected? What tests should I run?
Administrator
Had a 01 Taurus that did the same thing. If I remember correctly that only position where the compressor wouldn't run was the floor only position. How I noticed it was in cooler temps it would cycle on and off frequently and I could feel it while driving. I thought it was the lock up torque converter going in and out. Took it to the dealer and was told that was how Ford designed it and was normal.
Jwko nailed it. Its on all position except for vent to dehumidify the air.
Ok well that's crappy. I was hoping to start getting better gas mileage this winter when I didn't have to run my a/c.
But 85 just to clarify, the selector was turned to a position which pictogram showed arrows pointing out the dash and floor vents, no a/c or defrost symbol, and the pipe was still cold. To me this is a vent position.
Its been a while since I had a Ford with the pictograms youre describing, but I know what youre talking about. That position is mix, you can run both heat or ac in that position. In the earlier Ford models it used to say vent, I dont know what took its place but thats the one that the compressor doesn’t run. It should be between max ac and floor I think.
