Are you asking for advice or is this a rhetorical question?
Anyone know how hard it is to get a wrench on this?
I need to get 50/50 antifreeze in my truck but the tank and radiator only hold about 9.5 of the total system's 23.5 liters, so at the time I posted it was a problem because it was 12 C degrees below zero here last weekend. I wanted to drain the block because I had been running straight water for a while trying to clean up the gunk in the system, however the plug looked too hard to get at so I drained the rad and coolant tank then filled with antifreeze. At this point the easiest thing to do to get up to 50/50 is drain enough out of the rad to allow some more pure antifreeze to get me up to 50/50. So I don't require help now.
Glad you got it. Thanks for the update.
