ok on hot days (35plus-goddamed perth weather) i cant keep engine cool,removed thermostat just in case,no difference. running two large thermos side by side in custom shroud, pulling alot of air.but its getting hot even on the freeway.will slowly warm up and keep getiing hotter, and i'll pull her over and let her cool down,generally by pouring a ton of water over the radiator.that will drop it down. if its getting hot on the freeway,where its getting big air flow would this point to the radiator not being big /good enough?is a 3 core in good conditionrecently cleaned with both ends off and given all clear.car is 1970 mustang orig 302w now 351c.
will be trying the au thermos soon as they seem recommended for more suck when at idle but if i'm getting hot at speed does this point to something else?
so i'm thinking i need a bigger (custom? $$?) or falcon radiator or am i missing something? any ideas?
runs fine and cool on days under 30degrees
thanks
scott
thanks
scott
