Australian Probe Member
http://www.pitpass.com/news2/news.cfm?newsid=8214
In recent days there has been speculation at to what engines the various Cosworth supplied teams will be running in 2004.
As ever, pitpass went straight to the people who would know best, Cosworth Racing.
"Basically Jaguar will be using a development of the 2003 engine, which has been developed in line with the new regulations," a spokesperson told pitpass.
"Jordan will start and end the year with the same engine, in the same specification, as Jaguar," he continued.
"Any upgrades that take place during the year will occur on both team's engine," he admitted, adding; "although not necessarily concurrently.
"Minardi will be using a development of its 2003 engine, also to the new regulations."
Technical details:
Jaguar Racing - Cosworth CR6
Configuration: V10
Vee angle: 90
Number of valves: 40
Capacity: 2998cc
Maximum engine speed: 18,000rpm
Construction: Aluminium cylinder block and heads, cast in Cosworth Racing¬タルs own foundry. Aluminium alloy pistons, steel crankshaft
Engine Electronics: Pi/Cosworth
Spark Plugs: Champion
Dimensions:
Length: 589mm
Width: 538mm
Height: 454mm
Jordan Ford-Cosworth - Cosworth RS2
Configuration: V10
Vee angle: 90
Capacity: 2998cc
Dimensions:
Length: 589mm
Width: 538mm
Height: 454mm
Minardi-Cosworth - Cosworth CR3L
Configuration: V10
Vee angle: 72
Capacity: 2998 cc
Construction: Aluminium cylinder block and heads, cast in Cosworth Racing¬タルs own foundry. Aluminium Alloy pistons, steel crankshaft
Engine Electronics: Magneti Marelli
Spark plugs: Champion
Dimensions:
Length: 569mm
Width: 490mm
Height: 490mm
So now you know!
Not as detailed as the superceded specifications on the BMW engine posted a few months ago but it is our donk! :bsr:
