Ford Member
I have had Counter-Strike/Halflife/TF for quite some time now, but I reformatted my cpu and installed win2k on it and when I tried to reinstall CS it asks for a product key. I know I put one in when I first used it and never registered it but I can't get on to play it. I was wondering where I could get one without buying the game over again. Does anyone out there have a product key that they haven't registered that I could try. Thanks guys. I really appreciate it....
Keith
Old Skool Member
So you lost the product key? Did you ever register it? If you did try calling them, they should have your registration info + the product key on hand.
Good luck, hope you don't have to "borrow" someones product key, as this would be considered piracy, but I'm sure you already know that...
Beefy Big Poppa
If you own the game it should be on the CD case.. if not, I don't think anyone is going to give one up. I think the game checks each key against a master, so that if I gave mine out, I'd not be able to play online, if youj were online at the same time, and that would suck. What I usually do with keys is take a fine tipped permanent marker and write the key right on the CD itself, then put the CD into my CD wallet. That's not gonna help you now, but.. :) next time.
Ford Member
I had the case and I know the key is on the bottom of the disk cover in the white field. I just don't want to go out and buy it again.... Dayum this sux. I've looked for the case for 2 days now... I have the cd. I had put it in one of my blank cases and I guess just mis placed the REAL case...
Well i have a pirated serial list with everything from Windows XP proffesionall to Bryce 5 but i dont have your program,,,so i must say you are now screwed as im sure i would have been the only one to give it to you.
