I'm assuming the Momo item your talking about is the jobbies fitted to the ED XR6/8.BOF 351 said:was looking at taking the EA Ghia wheel although if the MOMO item is a decent price I might look into it, anyone got any idea what they are worth?
Funny you should say that XR8chic, the 'set +' button on mine stopped working the other day.XR8chic said:cruise control.????
they are those little buttons on the steering wheel that dont work!!
Sometimes the little bit of plastic (that 'actuates' the control) on the back of the swithch brakes off, obviously then it doesn't workAusXH said:
Anyone have any ideas as to why?
yeah - that thingobotch said:dont you mean switch kelli??
:s6:
Don't know if it's a N.O. or N.C switch. If it's not adjusted right it wont work. The plug for it is on top of the pedal box, make sure it's plugged in.XR8chic said:P.S I was told to check the bit that goes to the clutch as that might be causing the cruise not to work....
its possible... cos it stopped working after I got the pedal box done.
yes that fine, so tell me what's involved in setting up the cruise? will the green globe "cruise" be already installed? does it need anything else installed, apart from the device itself (near the brake booster) the steering wheel, accel cable, is anything else required or is it just a simple bolt together job? The Ford dealers in this town can have a cruise installed in a AU starting from scratch in about 1 hour so, this makes me think nothing major is required.botch said:hey bof, did you know that the cruise control (and accelereator) calbes are DIFFERENT (6cyl & V8)???
