Has anyone fitted a CSR electric water pump to a Clevo? If so what mods do you need to make. I know it can be done just not sure of all the work needed to fit'em up.
Brett
Brett
Hi Brett,just fitted one to my Clevo you can't use the backing plate that it comes with[windsor] -just fit it with out .I had to die grind a little on the inlets on the block and counter sink one bolt hole where pump fits on my motor plate because it overlapped [being a csr windsor it only has 4 bolt holes for mounting ]let me know if you need more help or a photoClevoCapri said:Has anyone fitted a CSR electric water pump to a Clevo? If so what mods do you need to make. I know it can be done just not sure of all the work needed to fit'em up.
Brett
304 EFI crapadoors came standard with extractors!!!ziggs said:i once did a efi course and the dummy motor on the dyno was 304ci 5ltr holden thingy and the motor was stock bar the extractors which added 12kw. we then put an electric waterpump on it and the thing added 18kw i stood there shell shocked i couldnt believe that u could gain so much, so i think u'll be quite happy wif the results of ur electric water pump and prolly well worth the effort.
xrglen said:304 EFI crapadoors came standard with extractors!!!
