S
The muffler/exhaust system on my '86 volvo 240 appears to have come
loose from its normal position - the tailpipe sticks too far out from
the back of the car, and if i tap it, it bounces up and down. i stuck
my head beneath the back of the car to see what was up - i noticed that
there was a metal pin sticking out from underneath the car that i assume
that the rubber contraption connected to the exhaust system with a
couple of holes in it is supposed to sit. i gently tried to stick the
pin into the rubber contraption, but the exhaust system didnt seem to
want to bend all the way up to the pin. i was afraid of pushing it too
hard - so i wanted to check to make sure that i was on the right track
before i tried to bend the exhaust system up to the pin. any
help/guidance is much appreciated.
smarthur
smarthur's Profile: http://www.usenetcars.com/member.php?userid=3381
View this thread: http://www.usenetcars.com/showthread.php?t=573916
J
Discussion Starter #2
"smarthur" <[email protected]> wrote in message
news:[email protected]
Yeah you're on the right track, the pipe or muffler inlet probably bent
slightly from it hanging like that. I usually lie on the ground and use my
leg to wedge the muffler up and then hook the rubber mount on, I've had that
same thing happen a couple times though usually it's the rubber that's
broken.
M
> broken.
What ususally happens is one of the joints at the front muffler or
catalytic convertor is a little loose. These can rotate when the rear
muffler hangs down like that.
Mike F.
Thornhill (near Toronto), Ont.
Replace tt with t (twice!) and remove parentheses to email me directly.
(But I check the newsgroup more often than this email address.)
1 Participant
Mike F
