Just want to tell everybody that has help me out THANKS! You been alot of help.But now that I am going to pull the Motor,damm I just might as well do this right and just re-do the whole engine(1997 4.6L GT) .I found this on ebay,and was thinking maybe go .020"(3.572") oversize on the bores.Is this package a good price,and if not were should I go.Because all the speed shops here in Tulsa are way to high!!Also does any body know of a good honest machine shop to take care of my needs .020" oversize bore.Here is what this package includes for $1349.00
This is a great deal! It is a complete STREET Rotating Assembly for 4.6 Ford Modular Engine SOHC or DOHC. It includes the following TOP OF THE LINE parts for your HIGH Horsepower Engine:
KELLOGG Forged 4340 Steel Crankshaft (stock stroke and journal diameter, brand new nitrided, racing oil system, inverse radius journals-good to 1000+ horsepower)
BRAND NEW 5140 Forged I-Beam Rods (With ARP Bolts. 650hp plus!)
Manley Forged Dished Pistons 18cc 3.552",3.572", or 3.582" bore [YOUR CHOICE]-(2618 Forged Aluminum. Fully CNC Machined, Tool Steel Pins, Wirelocks for full floating, 18cc radiused dish, Your choice of either 3.552"-std bore, 3.572" -.020" over, or 3.582" -.030" over bore, good for 1000+horsepower)
Plasma Moly File to Fit Rings (New low drag racing ring set made from the best materials. 1.5mm, 1.5mm, 3mm design. Super Flat finish increases ring seal as well as the best oil control.)
King Performance Bearings (main and rod bearings from premium alecular silicon material. Precision clearances, matched sets, tough to hold up to power adders)
This is the perfect kit if you are planning to rebuild your 4.6 for up to 650hp.
