1 - 10 of 10 Posts
So, I`m sorry that I`m writing about my problem in this section - but I really didn`t find a Ford Transit section.
I`ve got a ford transit from 2010 - cargo version
And today randomly while driving - the engine died in the middle of the road, I`ve tried restarting it and it worked for a couple of minutes while showing me that the temperature was above 120 degrees Celsius - It died again when I was close by home, and I tried restarting it - it worked for 2 seconds and died again - and the radiator fan started too.
Are any Ford experts here that may help me or at least answer my question?
Thank you!
Is the coolant low? Was it really running hot? Is it still not running? O'reilly's will check what codes it has for free.
The cooland seems fine, today - I tried to turn on the car and as I introduced the key and put it in ignition position - the temerature meter went instantly to over 120 degrees - and the car wont start
Does it crank over? Do you hear the fuel pump run for a few seconds when you turn the key on?
Discussion Starter · #5 ·
Yes I can hear the pump!
But it just doesnt want to turn on..
May it be the temperature sensor?
I havent used the car for 1 day - it was cool , and when I`ve put the key in first position - it showed me over 120 degrees and can it be from car`s computer - to not allow to start?
Sounds to me like you may have a short in the sensor or the wires going to it.
Discussion Starter · #9 ·
Hello Daniel, Just wondering whether you got your problem sorted? What was the actual issue and how didi you solve it? I have a Transit doing something similar. Thanks for any info.
1 - 10 of 10 Posts
