1 - 16 of 16 Posts
Blue Blood
Currently she's done about 26000km so its coming up to 30,000 service so I think I can wait until then however, i'm beginning to think my car has an electrical problem.
In the first 15,000km my car blew both front headlamps (low beam). I have now been driving on 1 low beam light for about 500km.
I've noticed since new that in lower frequency AM radio stations (774 for example) I can hear the engine through the loud speakers.
WIth the higher AM radio stations 1377 I can hear the windscreen wipers going (FM by its nature is protected against such electrical interference - typically).
I'm curious as my partners XR has not had a single failed headlamp, nor does it have the same issue as my radio. Nor does the dealer loan cars (XR6 auto and a XT wagon) that I have had when mine has been in for a service, nor has the rental that I had for a weekend in Sydney (a Futura).
Has anyone heard of these problems before? or might I have a legitimate complaint? (which I will bring to the dealers attention 1 week before dropping it off for service).
While blowing headlamps is more annoying than anything, 3 in under 30,000km is unacceptable, the radio feedback is certainly wrong - and if its "NORMAL" or "THEY ALL DO THAT" which they clearly don't.... it is a truly bad case of poor electrical design and isolation.
Thoughts?
Crazed Cone Chaser
By the sound of it, I'd say its an isolated case. But as for the cause? gods knows, could be as simple as one connection a little bit loose somewhere. or a small earth leak (not quite a full short circuit) where a wire has been pinched.
I agree, if they call that normal, then its a pretty crap car.
If they do go down this route, it should be easy enough for you to get them to see yours is not normal, by taking them round the yard and checking out all the cars there as a comparison.
Hope it goes well when it does get to the dealer.
Short answer, probably yes.
I have a BA and get engine speed related noise on the AM band.
Fairly minor but certainly present.
On mine sounds more like alternator related rather than ignition, but definitely related to engine speed.
No problem with noise from other sources, no problem on FM or CD.
On yours it's probably poor bonding of a ground connection to the body somewhere.
Ian,
If you have premium sound, then electrical interference is a known and common problem with no fix as yet. Interference gets worse the more you load up the electrical system. For example, use your demister, wipers, headlights & driving lights all at the same time and you'll see what I mean. Can't comment on the other stuff (but it might be related.
I have had trouble with blowing headlight globes on the AUII XR6. Done probably 3 sets in 30000k, but lights are just about always on. When the last one went i replaced both with Wurth Plus 50 globes and they have lasted the best so far 15,000ks and better light than standard too but a bit more expensive.
Good Luck
Blue Blood
It sounds similar to that - engine speed related as the amplitude and the frequency change as the revs build (very easy to notice when in a car park for instance).
So could be earth leakage from the alternator?
Must admit though I do notice it more when the driving in the rain (demisters/heater/wipers and lights going).
I wonder why the globes keep blowing though.
Tickford and FPV Bloke
probaly coz they dont like you??
Nah they are cheap crap ive seen a fair few BA's with blown headlights, its not uncommon thats for sure.
I seen an XR6 Turbo the other day, and the foglamps were full of water which didnt look too promising.
The feedback through the audio unit may be due to a poor earth in the aerial amp securing bolt which is located behind l/r c pillar trim. Have your dealer look at it. If it's overtightened it will destroy the amp.
Old Car:BA XR6 New: 97 EL
my old AUII blew 3 headlights within about 3 months... buding the whole 3 yrs i owned it.. never happened again tho. so i presume the OEM globes where just crap.
Hi All,
The engine noise through the sound system will be there forever with no fix. I have a v8 ghia, and added Boston speakers all around, and upgraded the amp. The noise inteference got worse. Had the inputs to the amps run down the transission tunnel, the power on the drivers side and the outputs back to the speakers on the co-drivers side.
Used shielded cable through out and now the high pitched hum is negligible, but as you guys said, load it on a rainy day with demister, etc on, you will hear the click of the relays on and off intermittent wiper come through the sub. Spoke to FORD CRC, and FMS audio, they said it was in all cars and I have minimised the problem as much as I can.
I had a recurrent problem blowing 20A fuses, rear light globes etc with my (yuk) Camry every time I towed a TRAILER.
Turned out it wasn't the trailer (I re wired it and still had the problem) but it was the $%#@! crap wiring connection from the car to the plug socket. The @#$!% towbar installer didn't allow enough slack in the wire and it rubbed through to short out on the towbar but only when it was under load.
If all else fails, I'd suggest tracing your wiring inch by inch from the headlights back to the fuse panel and see if there is a bare wire touching metal.
Thoughts?
Something to do with the supressor maybe?
PS. I have the premium sound interference issue as well, not as bad on FM as for AM. I've read its a common issue. I fitted the Aux plug as well and this seemed to worsen it. Use CD's and the problem disappears!!
hey boys,
i am new to this forum and this is the exact reason i joined up. i drive a 2003 xr6 manual with a stock stereo and it is rather disturbing hearing that i am not the only one with this problem, at first i thought it was because i am running it on aftermarket gas system. at first i thought i would need a gas surpressor to try and numb the interference, but reading up on this doubts my theory. to keep the stock deck in i ran high pass sytem to the amp and then back to the speakers (this is all done with speaker wires rather than rcas) that way i could leave the original headdeck in without putting an aftermarket one and still be able to run an amp and sub. what irritates me even more is the more tests we seem to do to try and illiminate problems the more walls we seem to hit. tried moving the earth to several places and tried using high to low filters to lower the interference. at one stage it work but what confuses me is the fact that the interference is temperamental. some days it is minimal and others it it unbearable. tested with headlights, high beams indicators aircon and electric windows
all seem to play a part. any ideas for any cures?
thanks boys
1 - 16 of 16 Posts
