I have a 1966 Mustang and the drivers door won't stay shut. The only way is to push/pull it closed and key lock it/push down the lock button. Any idea on how I can correct this?
I would be pulling door trim and checking lock linkage / lock operation as a first step .Could be something simple like a rod off or spraying with WD40 or similar might cure .
We had the same problem with my dad's '65 Fastback on the passenger side. It would swing open unexpectedly. No amount of lubrication would fix it, so I eventually installed a latch from a parts car I once had and the problem was gone.
