my ea falcon, multipoint, miss's every now and again at idel and the engine runs generally rougher than all other ea's ive driven, but it does have its power, ive replaced nearly everything, distributer cap/rotor leads plugs pcv valve, injectors cleaned out, compression tested fine done the diagnostic test it passes so i recon it has something to do with the tfi moduel, is their a way to test it and can it be taken off the distributer or is it part of it?
yes you can, you have to short 2 terminals out then connect a test light between 12v and another terminal and you count the amount of times the thing pulses to work out what code it gives out
wanting 6 gears!
daza_mate i have the exact same problem can't figure it out was gonna get the car sent in for a tune up but sounds like it doesnt help. Iv got a 89 ea s mulitpoint runs rough but has lots of power and does the ocassional miss. The main time its a problem is changing into second gear gets rough letting the clutch out.. any suggestions for me?
yeah well first you have to make sure all the basics are ok, plugs leads , distributer cap and rotor button fuel filter and air filter if it still runs rough do a compression test and if all that is gewd then you are in the same boat as me
