My EA seems to be running hot. On an average day (below 30 degrees) it will sit on half on the temp gauge all day. On a hot day 30 - 35 degrees, when I switch on the AC, the temp gauge will go to 3/4. Surely this is not right.
If I stop at the lights it goes even higher. I know EA are renowned for there cooling problems but I am unsure of where to start. I have 2 thermo fans in the garage which I could fit. I am not sure if this is the problem or the radiator needs a flush or something else.
Also could anybody post a brief rundown of how to wire up thermos!
All help greatly appreciated.
RIP Sox.....
You need to flush your radiator.
Your fan will be fine so long as it's the 10 blade unit rather than the 5.
Rick.
RIP Sox.....
The blades are roughly the same size, the 10 blade unit was fitted to later EA's as the 5 blade unit is not as efficient.
Rick.
my ea temp was up and down while driving i read a post on this forum about getting thermostat with holes in the body i did just that installed it and from that moment on drove like a charm temp never fluctuated again, dont ask me what it did but it worked i had replaced rad,water pump fan etc,etc and putting thermostat with 4 holes drilled 2 either side of centre done job unreal eh ?
regards
tbarr
