i have alot of noise coming from my valve train especially when i first start the car untill the oil gets to the top of the engine, then it quitenes down but its still very noisy, if i rev the car to about 2000 rpm you can hear alot of racket comin from in there,
iam going to see if i can get my lifters replaced , would this normally be the problem? is it common? anything else i should look out for?
Australian ED XR6 Member
HLA's(Hydraulic Lash Adjusters) are a quite common source of valvetrain noise on ford I6 ohc motors(ea - onwards)and relatively easy to fix(though can be expensive if you're unable to do it yourself)
Though there are other possible sources, I suggest you do a search on here for previous threads (noisy lifters should find you some info)
tip - remember to check yer headbolts whilst yer doing the HLA's
are the Hydraulic Lash Adjusters the same thing as the hydraulic lifters, because ive been suggested to replace the lifters
also i forgot to ask, will the valves be getting there full lift if the lifters are that noisy , hence loosing some performance?
