1 - 20 of 24 Posts
1972 XA GS Fairmont
What would you need to do to a 4.0L EB Falcon to get it running mid 14's?
Extractors, 2.5 inch mandrel bent system, Crow cam and chip package, port & polished head and cold air intake.
Would that have an EB running 14's?
Thanks Chris
LET EM' RIPPP
Just ask STOKEB. His best time is a 14.5, my guess, he will get a 14.2 sometime soon.
Just off the top of my head.
AU bottom end, AU head ported (not by JMM), Dev5 cam, JMM extractors, 2.5" zorst, 5 speed, 4.11 diff, pod filter.
He still has the stock ECU and fuel system.
Simon
Birth, Drift, Death...
depending on where you live, a custom surecam or a wade cam would be a better bet than crow - they can grind you a cam bigger than crow do for less money, and tailor the cam to suit your needs. if you decide to get a proper big cam then a chip would be benificial, as well as head porting...but decide if you are going to go to that extent BEFORE you get the cam - get the head done, then give the cam place the flow figures and they will do up a cam to suit it - it will go heaps better than the other way around.
3.9 diff gears and LSD (you would need a correction box to make the speedo and auto work properly) extractors of your choice (pacemaker race series, JMM or wildcat?) seem to be pretty good. quickcorty has pacemaker i believe (14.6 quarter) - but JMM are good too IMHO - and a 2.5" mandrel bent system with two straight through mufflers.
thermo fans from a EF are good to gain a few kW from, as are a pod and some kind of cold air induction setup..there are a million billion threads on here about what people have done...
you can ditch your spare tyre, jack etc, which might gain a little as well, but best of all its free.
try source some 225/65/15 brigestone G3s that are worn and put them on steelies for the back, they stick great if you get them nice and hot at the strip :s6:
You can now get retread slicks, you end up with a streetable slick. I think they go for around the $120 each whic isn't too bad.
Also you shouldn't need a correction bax for the diff gears, just change the speedo gear.
LET EM' RIPPP
Ford only make a gear up to 3.45 with stock tyre height. After that, you will need the correction box.
VDO make a unit, its about $200 I think.
Village Idiot
Depends where u are.
I picked up a 93 Fairmont with 212000kms on the clock for $3k
Pretty straight, few scratches. And interior little bit grubby here and there. Overall pretty good imo
No major problems
well my car is costing me 5k, yet i am buying it off my parents. click on the link too see my car. its in awesome condition
umm, the link isnt there, if you click on my name, and then go to my home page
1972 XA GS Fairmont
Discussion Starter · #16 ·
I would also consider buying an EA Falcon S if i found a good one. What did a standard EA run on the quater with a 3.9 Multi Point engine? How much could i expect to pay for a good EA? It would have to have the Multi Point engine. My old man had an EA for 7 years and the only thing that went wrong with it was he had to replace the radiator once.
EAs are lighter, it's true. They are also a damn sight cheaper. I usually wouldn't expect to see an auto EA crack $2k in W.A., a manual might go as high as $3500 if it was shmick. No XRs in the EA range, and usually you won't see people try to ask for more for an S-pak as they are not really very special. Only difference is badging, MINOR suspension, and interior trim, really.
I would encourage you to go this way, any part up to ED will bolt straight in with a very few exceptions, and many of the EF/AU bits will fit easily as well.
Personally the driveline is your biggest holdup, IMO if you leave it auto you are wasting your money. That 4speeed box will never push you to those times without spending vast amounts of money on either huge KW or the box itself....mush better to go to the 5speed I reckon.
I am still considering goin down the manual way when i get my AU engine. i think the auto is playing up a little!!
mongrelEB, good to see you are back on the forums!!!
cheers oed :)
1972 XA GS Fairmont
Discussion Starter · #20 ·
So what should i look for an EA or an EB? Also whats the go with the XH Snorkel? Are they a bigger intake that can be bolted onto a EA or EB?
1 - 20 of 24 Posts
