hi ive got a eb s xr8 thats got crow stage 3 cam double valve springs au 220kw intake 75 mm edelbrock egr plate and throtle body car is 5 speed with cushon button clutch stage 3 j3 chip from tiperformance and today i purchased a vortech supercharger do i need a stand alone ems or will j3 and standard ecu work any advice would be great
Got to looking into it, looks like you can do it with just the ECU, I'd have thought you'd need to piggy back, but remapping of the ECU with the assistance of a Dyno should do the trick. In either case, it's going to cost you some coin.
ive been in touch with tiperformance and im getting a stage 3 j3 custom tune for boost and a widebaned co2 controler and a wideband co2 sensor hopefully this does the trick if not ive got a wolf 3d laying around just need the wire harnes thanks for your help catskinner
